Trip
I want to build a setup for low and mid range power/torque, having high end power would always be a bonus. Car will not be used on the road so there is no need to be street legal :-D
I am going with a 3071R with external WG to match my DP manifold with T3 flange. I am not sure if I should go for the 0.63 or 0.82 AR. The wastegate will vent out separate from the exhaust. Between the turbo and inlet manifold, I am opting for a water/ice to air charge cooler to minimise the piping and hopefully minimise lag. Anti-lag is also in the equation.
Have some questions for the GTi-R experts.
1) Since I want my low and mid torque high, would I benefit going for a higher rev limiter to get some more high end power ?
2) Should I get tomei/jun cams for low/mid power or standard cams will suffice?
3) Where is the best place to get the head ported and polished for maximum flow?
4) Lag difference between 0.63 and 0.82 ?
5) If I had to go with a higher rev limiter, will I need uprated rods ?
Anyone with more insights/ideas about my goals who would like to share, please do so
THANKS
Ev
THANKS
Ev
