Brake's - ABS or Not??
Fazz
I noticed a dramatic improvement on removing my fuse and de-activating the ABS..
Thinking of keeping this permanent if the light doesn't bother..
Running on Wilwood 4 pots with 280 discs and fast road pads - came with wilwood. Braided lines too.
Many here running with ABS?? or most not using it?
Ive still got it but i'm seriously thinking of binning it ;-)
I've had a couple moments where i've nearly hit things due to the crappy abs deciding it wont let me brake properly :evil:
abyss
I took the fuse out months ago the Abs on these cars is a hazard. Brakes feel more responsive. I have removed the bulb from the clocks and plan to put the time in the space where the abs light comes on.
6
6Miester
How much of a hassle is it to remove the bulb?
My ABS is playing up even after loads of grief trying to fix it. Problem is my MOT is coming up so it would be better to remove the bulb and fix the fault after when i have more time.
Any tips on what to do?
Cheers in advance!
