The reason for fitting the primera egt one is it has a larger piston bore which means when you are using multi-piston calipers with more fluid in you will have a firmer pedal, less travel and better feel to the brakes mean easier modulation of braking force, just because the pedal feels 'ok' with the standard master cyl doesn't mean it couldn't be better....that is the reason for Stew's question....
