brake master cylinder
matp5
Anyone know if theres a brake master cylinder repair kit? I know theres one for the clutch master cylinder, but can't seem to find one for the brake... Or anyone know the part number for the 2 cylinders? I think it's 46D10K ???
thanks
gtiroz
Administrator
46010-0N620 = cylinder assy-brake master (alt: 46010-69C21)
46011-69C27 = piston kit-tandem brake master cylinder (repair kit)
matp5
Thanks for the part numbers! Is it worth to change the whole master cylinder assembly? I was thinking of changing just the two cylinders...
The problem is that you can't tell if the thing is all scored until you take it apart to rebuild it, then it's too late because you've already bought the rebuild kit and not a replacement part. - It's a more expensive decision, but probably wise to heed stumo's advice for something like brakes; they could save your life.
