boost suddenly reading 1.3, normally .7! Help!
Car is running standard boost(normally) and has a mongoose exhaust, other than that it's standard. Now boost has shot up to 1.3. Any ideas why?? Also anyone know of any good tuners near suusex?
Uhoh that means your running unlimited boost! be very carefull as you'll blow the head gasket shortly! get it checked out ASAP!
Hope that helps!
Nick
C
charlie
If you still have a top mount i/c has it been off recently? If so then chech the far right corner of it (looking from front of car) there are 2 small pipes which are the pressure feed to the actuator. If one of these is off you will run unlimited boost :shock: also make sure theres no splits in the pipes o the actuator, and the pipe is still on the actuator itself.
