D
DodgeT
as above, trying to fit my autometer gauge, but can i find anywhere to poke the hose through the bulkhead, can i chuff
where do you go through????
PMSL!! Yeah should look good too!DodgeT said:im just gonna go out the side of the bonnet, up the middle of the windscreen then down through the sunroof
thats gotta be easier than tryin to get in there to get that bloomin hose through.....
i wish i was a midget :?
Yeah but that's a pig to get to from the inside of the car.memski said:Also if you don't have a/c anymore you can use that hole behind the glovebox 8)
That's where I put mine. I took out the main dash and vent surround and drilled a hole throught that so I could thread the illumination wires and pressure hose through to make it look nice and tidy. I can try and take some phoyos for you tomorrow if you like (off my phone, so they'll be shite).think im gonna mount it on top of the steering column cover, in the middle, so as you look at the speedo / rev counter, its right in the centre of them 2. should be nice & visible.
yeh, will give me an ideaI can try and take some phoyos for you tomorrow if you like
just done it like this, seemed like the easiest wayother grommet is on driver side, on the firewall in engine bay you can see a hole there and stick your hose thru that hole and using other hand you stick your hand under the front guards, (under the mud guard cover "or watever you call it) you can push that pipe through another hole going through the driver side. It's a pain for this one cause of the tight space and it's best you have small hands! The hose should then come out just above your pedals. I managed to squeeze in a 0 gauge amp power cable and another power cable for my second amp. Plenty of space through that hole
