Boost duty on Apexi AVC-R
Pulldog
What does the boost duty mean on the apexi boost controller?
moved to correct section- Hannie
Pulldog
re boost duty
Well what if i increase or decrease the duty what will happen DP have set it at 34%
Curtis
If your not reaching the desired and set boost level you need to raise the duty.
If you boosting over the desired and set boost level you need to lower the duty.
Have they set it to 34% across the board and is it self learning yet?
PS. 34% is quite low, is that for standard boost?
I think for 1bar you need it set to 54% ish as a starting point and let it self learn.
DP know there stuff so it should be correct, but worth checking with them as anyone can make a mistake...! :wink:
Pulldog
Yeah DP set it at 34% when the car was at 10psi but when i got home i put it up to 1 bar but i have only ever reached 12 psi il try and increase the boost duty to around what you said and c what happens thanks for the info mate
Cheers!
Curtis
Set it to 54% on the front screen and not by adjusting each point of the rev range as that assumes that you know what your doing and it won't self learn. You should get three stars *** to show that it's learning. :wink:
Pulldog,
I had a really good session on the dyno at abbey to esnure I got good spool up at various boost settings.
if you have the std setting at off then it will set it self to the std actuator boost which is 0.65 bar on my car.
what you need to do is going into setting B, then use the self learn part, and then increase the incremements along the graph levels for boost and duty cycles.
For low boost (0.85) I run like 38-42% duty cycles across the rev range right up to 7000 rpm. by then the hyrbid T28 I have on the car is out of puff so no pont in keep upping the duty cycles as you will just be wasting yr time and the turbo is out of the efficient zone. I have like 42% at the start of the NE cycle to ensure the solenoid is open enough.
At high boost (1,1 bar) I pretty much run about 58-62% across the range depending on the revs. We have it up to 62% at 2500 rpm to make sure she spools up really quickly, which she does :lol: and then set the duty level to whatever was needed to ensure I had a flat boost curve right across the range. If i remember correctly I am at about 60% across the range.
the dyno print out does revela a quick spool up and she holds bost flat right until 7k rpm. that is the beauty of the avcr that she will hold boost consistnetly with little spikes.
A rolling road does help as it will measure the boost, how it reacts to the changes and what duty cycles you should be running.
I really noticed the difference in the car afterwards as it just picked up so much better.
nick
Pulldog
CHEERSV GUYS BEEN A BIG HELP AND CLEARED UP SOME THINGS LIKE I THOUGHT THE THREE *** MEANT THE COMPUTER HAD FUCKED UP BUT NOW I KNOW AGEN CHEERS LADS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
