Boost Drop
GTI-R Nath
is it normal for the boost to drop slightly after fitting a front mount intercooler,
im just using the 1 bar loop at the moment but before i fitted the front mount the standard gauge would go past 7 mmHg on full boost, but now it stops just before 7mmHg
thats because youve removed the restrictor pipe (has a green or purple band round it) close to throttle bodies
put it back and all will be fine
GTI-R Nath
is it a vacuum line i used a new pipe between the t piece and the throttle bodies, think iv chucked the old one in the bin too
GTI-R Nath
just had a look there is a pipe with a purple band after the t piece near the actuator but i cut it about 2 inches after the purple band and joined a new hose to it with a joiner, is this what's wrong
yep itll only hit about 0.5 bar without the restrictor in place unless you have an aftermarket boost controller fitted
GTI-R Nath
the pipe with the putple band is still there and car still feels as fast as before, only thing thats changed slightly is the gauge reading,
the pipe needs to be fitted off the plenum side of t piece ideally closer to the plenum as poss, plus make sure youve not cut the plastic restrictor thats fitted inside
