Boost Controller Help
R
rice_thief86
I have purchased a Turbo smart T-boost controller its mechanical i have connected it up right and its by passing the stock boost solenioid. I turn the dial a few clicks and it keeps cutting out like making back firing sounds. The boost reading at abt 10psi which is still stock. What can i do to overcome the boosting situation??? by not replacing with a electronic boost. :?
Dooie Pop Pop
check the gap on your plugs its too wide probably. it should be .9 for standard plugs or .75 for iridiums.
Trent:dont talk about fcd' s you' ll get banned (by me)
sounds like your sparks being blown out, maybe faulty/old ignition components
R
rice_thief86
yeah i have iridium in my car they are a bit black so could that most likely be the problem???
R
rice_thief86
well im gona go get some new pulgs and if that the problem. But the thing is that if i was running 13psi the plugs wont last that long is this true????
jpward
When you say "Connected Right" what way did you connect it and what hoses did you use etc?
Dooie Pop Pop said:
check your plug gap if thats ok start replacing ignition bits
Before you start replacing bits, try a fault code check just in case. (it's free and easy);-)
