Right first of all, a few weeks ago I killed a Turbo, basically the impellor was not well and it had so much play in the shaft the fins ended up hitting the housing causing damage to the turbo, anyway, I have another Turbo on there now, boosted up fine, but ive noticed if I give it some beans and take it to about 6.5k and do a quick gear change, sometimes it looses all boost, then suddenly picks up again, this only happens when I hit higher revs. I thought this would maybe be the recirc dump valve sticking or leaking, but ive changed it for another and its still doing exactly the same thing.
The only difference today is after I had the lack of power after hitting high revs there is a slight difference in sound when the turbo spools up and for a second on initial boost up it sounds like there is an air leak somewhere.
Its so annoying ive had all the pipes off when changing theh dump valve and everything was nice and tight, couldnt feel or find any leaks in the pipe work.
I was wondering the initial problem with it loosing boost pressure after high revs would down to a sticky Actuator? anyone had anything similar?
Theres no hesitation, and pulls very freely up the rev range when its boosting ok, generally drives fantastic, no missfiring, idles perfectly. If there was an air leak I would have thought the idling would have been a bit rough.
Any thoughts would be great
Thanks Sam
Thanks Sam
