my bonnet seems to lift a bit more than i'd like at speed & I can notice it move up and down with the wind, it moves about 1cm up & down. Is there anyway of adjusting anything? It opens & closes fine.
i watched 00sid sort mine out take the grill out and shut the bonnet. undo the 2 (14mm iirc) catch mount bolts behind the horns, adjust with a bar and hold in place whilst retightening. job done
my horns arn' t in the same place anymore so im not sure if you' ll need to take em off.
There is an adjustable rubber stop underneath each front corner of the bonnet that you can screw in and out to line up the bonnet and stop it flapping in the breeze. That's how I sorted mine out
