Blitz R-VIT questions
GTI-R Kid
Hi folks.
Been doing some research into boost controllers and I've almost settled on the Blitz SBC-iD III, having read the reviews and opinions from a number of sources.
After flicking through the current issue of Japanese Performance magazine I see they're fitting the same controller to their drift project 200SX, along with the R-VIT monitoring tool.
So the questions;
Has anyone got one of these fitted?
Find it any use?
Can it be hooked up to a laptop to download recorded data?
How handy is it to have the ability to monitor the different areas of the engine - do you actually use it or is it just a distraction?
Is it worth the money or should I save a little longer for the R-FIT fuel controller to match the SBC? (aim is 1-1.2bar max with upgraded fuel pump and fuel pressure regulator fitted).
Any info/links/opinions appreciated. :wink:
How much are these two controllers going to cost you fella?, You must be getting in to power FC thought of money :? :idea: .
rob
Dooie Pop Pop
id wait if i were you or at least get the fueling checked asap. iv got the dsbc and i found it to be pretty good and easy to use 8)
