Had to remove rear brakes, strip clean and free up. These are front brakes used on rear. Drained out all fluid, and refilled with new. Can,t for the life of me get a hard pedal. Pump up hard, release pedal and all gone. I use air line at 18lbs and can usually do this myself. However had Cliff inside pumping away using lots of fluid but still no pedal. Car is fitted with hyd handbrake. Taken off master and inspected. This looks in lovely condition with perfect bore, and seals seam to be ok looking at them with mag glass. Tried every coupling looking for a bubble under pressure. ANY IDEAS. den.
