BLEED VALVES AND BOOST
C
carterjohn
my car was set at 1 bar,messing about the other day i turned it (wish i hadnt) ive tried to get it back where it was.but i end up with the car hesatating at low revs or the car holding back at high revs.HELP :cry:
POWLO
i had the same kind of problem the other week, don't like the things keep getting boost spikes, and just a horrible and tacky way of getting the bosst up.
Best thing to do is to close the bleed valve totally, means you will go back to 0.7 bar which is the factory setting, then from there if you do want to turn it up then do it a bit at a time the drive the car to chack i9t out.
To close it, you should turn it clockwise, well that is how mines works.
Hope that helps. :)
Fire & skill
Vintage member
should also have said - bleed valves are so 80's :oops: relief valves are ok - as they actually work, but you need to sort your fuelling out as well or you will soon know what 'the big bang' is
C
carterjohn
should of said the car has a walbro fuel pump,fmic and super hybrid turbo
