big brake kits
STU666V
Anyone interested in all sorts of brake kits?
They a K-sport kits.
Got a email ftom them last week and they are willing to make kits for us.
STU666V
Hi,
We can do the brakes, what size wheels do you have?
This will depend on the brake size 286/304/330/356 for*15/16/17/18" wheels are available. On some 17's customers require a spacer to clear the large caliper of the 330mm kit.
We can provide brake fitment templates to ensure you know if the brakes will fit and if a spacer is required behind your wheels.
Various pads are available but for race use I would suggest the Pagid RST3 pads - an evolution of the RS15's if you are using the 330/356mm kits or the RS15's if your using a 286/304 kit as the RST3's are not yet available in the required pad shape.
Sorry we don't do the KSport coilovers but we do the BC racing ones.http://www.bc-racing.co.uk/applicat...n14-91-95/br-series-coilover-type-ra-1.htmlWe can do these with your choice of spring rates, and can even do a more aggressive "race damping" setup both at no extra cost.
The springs are linear springs. The topmounts are camber adjustable.
We would normally supply this kit with 6kg front with 120mm travel, matched with 4kg rear 150mm travel. But your spring rates will not be a problem.
Yes the damping and ride height are adjustable, it's a single point damping adjustment.
We don't specialise in ARB's but are a whiteline dealer.
ThanksKev*
johnny gtir
Doubt it will stu but if it helps in anyway as sometimes its the desing time they try and get money back off as the calipers and disks suit many aplications i have a few brackets. Tarrox 6 pot to suit 288mm
Tarrox 6 pot to suit 330 mm
Bigger front disk standard calipers
Wilwood 4 pots
and for the rear goodspeed 300mm standard caliper
k sport 4 pots vented 300mm
280mm disk brackets suit standard caliper
Just to point out that K-Sport already do kits for the GTiR
I'm using the 304mm 6 pot kit and they offer a 330mm 8 pot kit already.
Not sure about rear kits, its has been mentioned, but I've not seen anything and when I spoke to them they were not interested in sorting out the handbrake system.
Also to note, after service from Apex (K-Sport in disguise) was total bollocks! I've contacted them a number of times regards spares and parts and even a problem with my caliper mounting bolts and on all occasions they have never followed up or sorted out any of my issues.
As far as I care, Apex are suppliers of parts...that's it! No customer service and their comms is total shite!
Sorry Stu for being negative here, but I feel that its important that I stress my issues and dealings with Apex!
STU666V
Ok thanks for the info lads.
They are not for me it was just for other members.
Am making up my own kit as am going 5 stud.
