H/G thickness depend's on wheather you have had the head and/or block skimmed,and personally i would go cosworth as you can get the right bore size to suit your car (i.e 86mm,87mm etc) You do have to take the dowel holes out bu .5mm to suit our engine and grind a small section off when fitted to clear the drivers side engine mount ,but apart from that they are spot on.
