Its the msd ss blaster coil.hmmm said:Hope you don't mind me asking here, but which Coil did you use? Was it a Standard Nissan one or an uprated one like the MSD?
Now, back to the topic at hand .
nismoboy said:Ive ordered some new magnacor leads and ngk iridiums heat range 9 so i`ll see if this gets rid of the missfire.
It does seem to be a common problem tho i`ve been told when upping the boost that miss fires can happen on a pulsar, I personly think its just the boost blowing the spark out?
ive now done the above and it seem alot better, but today when racing a 600cc bike i got a missfire in 2 2nd gear around 6-7000 rpm ? So i gues the problem still hasnt gone its just moved, i was getting a missfire in 4th and 5th high in the revs but that seems to have gone and now it missfired high in second gear. any ideas?
things ive done so far..
removed msd coil and replaced it with old nissan one
new magnacor leads
new ngk plugs
might try fitting a new ignition amplifier any one know how much these cost?
thanks nis.
And guess what! NO it dosent :evil: :evil: it still missfires, so back to the drawing board.nismoboy said:I took my ignition amplifier off the car today and i when i took it off the bracket plate undernearth was covered in gearbox oil, so ive cleaned it all up and removed the paint on the contact side of the bracket for a good conection and put it back together so fingers crossed. I also relocated the ignition amplifier over to the near side wheel arch away from the heat of the engine as my problem seems heat related. i`ll let u know if it fixes the missfires. cheers nis.
its not really nasty, it just stutters and popsDooie Pop Pop said:if its a really nasty missfire i had the same problem with my car after the fueling had been setup completely wrong. sounded nasty like antilag :shock:
