skiddusmarkus
After hibernating in my garage for 5 years or so, my old black money pit is officially out of retirement.For those who care or don't know it,the spec is roughly(I've prbably forgotten stuff):
Engine:
Tomei 260 cams
Tomei rocker stoppers
Tomei valve springs
HKS cam pulleys
Tomei 1mm head gasket
Mild polish on rebuilt head
Nismo headstuds
Tomei 87mm pistons
PAR conrods
ARP rod bolts
JUN(aka cosworth)crank studs
Lightened/balanced crank
Forge alloy pulleys
Mildly ported standard exhaust(heat wrapped)
Intake:
Blitz sus filter on home made induction pipe
Turbodynamics md214 turbo
Forge FMIC
Home made air scoop fed by sparrow slicer
HKS SQV
Felling:
Sard FPR
Walbro pump
Sonnicly cleaned injectors(until run in)
Cooling:
Koyo alloy rad
Mocal oil cooler
Samco/silicon hoses all over the place.
Chassis:
Fully polybushed using whiteline/powerflex stuff
Nismo engine mounts
Front upper and lower and rear upper cusco braces
Tein SS coilovers
Tein EDFC damper controller
Bumpsteer mod
Cusco 6 point bolt in cage
Hispec 300mm discs with racing 4 pot calipers
Rear 285mm disc conversion(martin bell)
Whiteline front and rear ARB
Steves brake master cylinder mod
Volks TE37 with 215x50x15 T1-S
Transmission:
Helix paddle clucth
Jun lightweight flywheel
Nismo front and centre diffs
PAR gearset with 10% shorter 3/4/5th and yes, it works as Bernie built it.
Interior:
Knocklink knock monitor
Knocklink lambda gauge
Greddy egt guage
Greddy e-01 boost controller
Tein EDFC controller(adjust dampers from inside the car)
Stuff in the process of going on:
Janspeed 3" elbow & downpipe
Aquamist system 2d water injection
MSD 6200a ignition box
MSD coil
Cobra suzuka driver seat(has been and out, struggling to get it to sit right)
Cobra imola 2 passenger seat
3" intake with Z32 MAF and recirc plumbing for BOV
Blitz 700cc injectors
Innovate LC1 wideband lambda(greddy e-01 can display the a/f)
I have missed some stuff I'm sure.
First drive and took it pretty steady until I got on the dual carriageway, then it did the usual trick of blowing a boost hose off when it hit 0.65 bar(its running on wastegate until run in)which for a split second makes you think a ring has gone or the HG.Popped it back on and came home to retighten all the hoses and took it out again and it was fine.Feels very strong in 1st & 2nd but after that there are noticeable flatspots so is in need of mapping as soon as its run in.
Engine:
Tomei 260 cams
Tomei valve springs
HKS cam pulleys
Nismo headstuds
Tomei 87mm pistons
PAR conrods
ARP rod bolts
Forge alloy pulleys
Intake:
Forge FMIC
HKS SQV
Felling:
Sard FPR
Walbro pump
Cooling:
Koyo alloy rad
Mocal oil cooler
Chassis:
Nismo engine mounts
Tein SS coilovers
Bumpsteer mod
Transmission:
Helix paddle clucth
Interior:
Greddy egt guage
MSD coil
