E
Edd
Right fitted my AVCR and set it up fine, however have a couple of queries.
I wired the one wire into the rpm signal instead of injector signal, but i still get a changing reading on the injector duty BUT it goes down, ie i get 86.4 % on idle then it drops to say 30% on full throttle. Is this working properly but on a bacwards scale, ie you have 30% duty left.
Also on the throttle one i presume it is measuring the percentage of throttle, ie 0% nothing, 100% is full throttle. (i havent read manual so not sure but presume this :roll: )
In 2/3/4th gear i am getting a variance of about 80-96% throttle when floored, does this mean i have a bit of slack in my throttle cable and im not getting 100% throttle?
As at times its only hitting 72% when floored
