Hi
After my recent quest for an arc tmic Pulsarbob kindly found me one, which i was delighted about. so thanks Bob!
I have just fitted it and on the top side (bulk head) just before the rubber hose connector i noticed a small 2-3 mm hole in the arc pipe, the hole goes all the way through the pipe. Is this the way arc tmic's are or is it the case that i should block it. After speaking to Bob he said i should ask the question on here.
I drove the car with the hole blocked and unblocked and did'nt notice any real difference. Both myself and pulsarbob thought that it would loose boost pressure with it open.
Any thoughts on this are much appreciated.
Kind regards
Kind regards
