apexi safc2 question?
sweetyGTIR
just a quick question, ive searched the forums for this but couldnt quite find the answer i was looking for.
i bought an safc2 a few weeks ago an i want to fit it this weekend, what i want to know is can i fit it and use it purely as a monitering device( no messing around with it) just initial set up until i can get it to a rolling road for a proper set up?
list of engine mods so far
all hks internals
blitz hybrid
pace fmic an rad
nd top mount oil cooler
blitz filter
apexi avcr
uprated fuel pump and injectors
other bits an bobs
running 1.3 bar
i dont want to pay someone for something i can do myself, the only thing is i dont have a rolling road in the back yard that i must pay for.
any help much appreciated.
thank you
Rishi
Still waiting on some shims!
You can't leave the settings to 0 because you have different injectors... You need to setup the AFC for these...
Rishi
sweetyGTIR
Rishi
what settings would these need to be on to compensate for the bigger injectors.
Simmo
i think with 555's you can just reset the upper and lower correction factors (use the same procedure that you did for the std injectors - http://www.apexi-usa.com/pdfInstallation/15.pdf
You might find that you might need to reset the deceleration upper air limit setting aswell.
Its pretty much self explanatory - ie the manual says what output you should have from the safcII during/after setup
hope that helps mate
