Apexi Avcr Scramble ?????
SickBoy
2 questions really
firstly it appears that the scramble only works by using a open switch connected to the orange wire not via a button on the controller ?????
secondly the setting only lets you go up to 1 bar so is it a setting above the setting you are running ???
IE if you running 1 bar set scramble to .2 bar thus does that give you 1.2 bar scramble ????
Any info apreciated
Lee
jiw
You have to go into the settings and select scramble, set the target and duty for scramble and also the time you would like to increase boost for, you will also need to wire in a push to make switch to activate scramble.
