justin666
Hey you..[]
Right, Finally just finished getting the apexi avc-r in my r and I just wanna confirm that i got it right.. It appears to all be monitoring OK but for some reason it dont seem to be controllin boost..!!!![B)] Now, rather than this being a problem with the apexi, its more likely down to me bein a crappy mechanic.!! Electrics i understand but engines I dont..[xx(]
So.. Tell me if this is right....
Starting with the solenoid valve.. I have the com port connected to the actuator.. (correct.???) The NQ port hose goes to the connector under the right side of the intercooler as u look at it from the front (correct..??) I have closed off the hose that goes from the induction pipe (air filter to turbo) to the old boost valve and also unpugged the electronic connector to the old boost valve (correct.??)
The pressure sensor, i have t pieced this into the vacuum hose that goes into the back of the IC.. (correct..??)
What am i missing here..??? have I got all this pipe work in correctly..???
Any help greatly recieved...[]
Thanx in advance guys..
Laters
J...
Come get your OATS..!!!!
Laters
J...
