Ok next question - What in the diagram does "IG1" and "IG2" mean? I presume its just ignition position 1 and 2?
Also need to know where the ECU is located , and the colour and pin designation of the O2 sensor wire and the ECU earth.
Any help appreciated.
It came with a mistsubishi harness, i just used a multimeter to check the which wires were which in my ign, and then swapped the terminals in the harness plug to suit. The mitsubishi harness is very similar so with slight modification of the connectors it plugged in.
