Apexi AFC question
SunnyGTIR
Just fitted an AFC to the R but need someone who has one to confirm the sensor type settings. When you press 'sensor type', then 'Hot-wire', then you get 'sensor no. IN and OUT', then 'sensor cal. IN and OUT'. What numbers should be under these INs and OUTs. I've tried the manual but cant make sense of it :?
Want to make sure the car is set up right so I can drive it to get mapped :)
Thanks guys,
Thor
which colour of wire you fit on the ecu??? i have trouble with the guide. my + power is not on the place which is in the manual guide...
cheers
sascha
SunnyGTIR
I got all the info off the Apexi website. I went off pin numbers as there are a lot of the same coloured wires on the ECU.
Thor
i have it made too, but my power wire is everything on!!! so it must go on when i put switch power and not when the key is outside...
SunnyGTIR
Is there no-one with an AFC that can help me out here :cry:
Pretty please :wink:
MORRISMINOR GTI-R
hi mate, mine are both set to 5 and the car runs fine.
Dont know if this is right but it runs ok. when you change them to 0's the car will cut out.
:wink:
