About the item:
Travel distance per gasoline 1 liter- Before the installing 3.60Km
- After the installing 4.02Km
The blowing to the high rotary limits it raises, can realize the change of shift timing! As many as 12% thing fuel economy improvement was actualized with in the severe race scene.
Ignite VSD boost raises the input potential to the ignition coil to 16V, maintains voltage in 16V furthermore in the time of electric load, supplies the voltage which is stabilized to the ignition coil.
¡EThe blowing rising is different.
¡EPerfection obstruction misfire of TURBO high boost engine.
¡EPowering down at the time of air conditioner is prevented.
¡E Powering down the power usage of audio on-board car is prevented.
¡E It is adapted to various motor sports.
¡E The protective function which does not produce effect to either the
up-to-date DLI ignition coil.
¡E When 10,001, trouble occurs in VSD, the relief design where LED goes
out, automatically changes to the 12V circuit .
¡E When at the time of high load at deterioration of the battery and the
time etc of engine starting low it becomes voltage, it changes to the
12V circuit temporarily and the circuit damage protective function
which again changes to the 16V circuit at the point in time when the
load cancel.
load cancel.
¡E With power source relay attachment the efficiency of VSD-H II 100%
showing.
