any ideas?
R
RJC
I have a standard R Sometimes it feels really quick, but sometimes it doesn't.
It feels like it's holding back, the induction kit sounds like it's drawing more air and the oil pressure runs a little high. The boost gauge shows normal boosting, fault code check is 55, and it's not heat soak. Any ideas, it's doing my head in?
jiw
sounds like mine mate, its getting better but im going to get it tuned once all the latest buys are fitted, very annoying, it seems worse in the higher gears too, the only parts i aint tried are a different ecu and maf, jeff
R
RJC
Have you thought it might be the boost solenoid?
hmmm
This is only an idea but do you guys think it could be something like the turbo hoses being knackered? :? or may be even the fuel filter? :?
It's just a thought, I don't really know. :(
Stevo
i get this i reccon the following may cause it.
aircone sucking in hot air, if not moved to were battery is.
coil pack are knowen to be faulty when hot or been used on long journey
fueling is to rich causing back mixture
