if your actuator is set wrong the waste gate will stay open if your sure no gaskets are blowing you ever have a cracked housing( although unlikely if you say turbo is new) or wastegate not closing properly!
A screamer pipe will always sound like a tractor at idle!!
It's the same as having a big f00k off hole in your exhaust.
It'll only sound good at high revs, Thats why they call it a screamer!
If the turbo is interally gated, then the waste gate should be closed at idle, (or very close to it). If the matching on the downpipe/elbow is near perfect, then the noise shouldn't be there until the wastegate opens and lets out the waste gate exhaust and noise.
