sweep121
When I'm driving miss daisy there's no problem but when I start to boot it it at first seems hesitant as if there is a barrier then you need to boot it right past the barrier if that makes any sense, then when it is full pelt the boost kind of woozes up and down with the occasional pop of the exhaust and psshh of the dumpvalve(which was new when I picked it up last week)
When I picked it up last week it seemed to hold the boost okay, there was a bit of hesitance, particularly in fifth gear, it got to 90mph okay but if you wanted to gradually go beyond there was a big induction noise. If you planted it it would fly off like a rocket but there's not really a smooth way to do it. Accelerating at 90mph was almost is if i had the foot on the brake and the induction noise gets deeper, I hope someone understands what I mean.
car has following mods
front mount ic
mongoose and decat
3 inch elbow downpipe
blitz boost control set to 1.1 bar of boost.
k&n induction
previous owner was going to get the uprated actuator fitted but i had itchy feet and picked it up too soon. It doesn't hold 1.2 bar of boost
is anyone familiar with the blitz boost controller? i'm not sure what the 'gain' means or what it should be set to.
is the uprated actuator easy enough for a competent mechanic to install and should that perhaps make a difference?
cheers lads
front mount ic
mongoose and decat
k&n induction
cheers lads
