Hi all,
I have a question:doh: and this may be the noob question of the month;-)
I am going to get my car mapped to run 1.2 bar. I will be running an uprated fuel pump, boost controller, fmic, filter, uprated clutch.
I have read on the forum that there can be underfueling issues when u raise the boost, would this be the case if I get the car mapped correctly to the level of boost i wanna run.
Worst case scenario and I do have an underfueling issue. I could fit an AFR and increase fuel pressure? - but as I have read on various posts an AFR is not really required (unless your running big power) - if anything I should just replace the standard fuel regulator as I will be running over 300bhp.
I was thinking:doh: to be sure that I dont hit an underfueling issue i could fit slightly bigger injectors? 560cc? and have these mapped correctly and this should allow me to keep standard fuel pressure, I hope!
My thinking behind this.... a) I hear that raising the fuel pressure above the standard 3bar pressure can split the standard fuel lines. b) I am also replacing the worn parts on the gtir and im sure my injectors have never been changed, they are bound to go sooner or later and im sure the car will run better with these replaced anyway.
All help is much appreciated and all noob bashing comments will be taking in good hhhumour
Jonny
Jonny
