AZ STE
Hi,
Im removing the standard airflow meter to turbo pipe. There are three pipes going into this:-
1. Return from the standard dump valve
2. Small pipe going to a switch on the top right of the rocker(bleed?)
3. Crankcase breather
Obviously I can do away with the dump pipe but can you remove the crankcase one and simply fit a short pipe with a filter on it (anyone bought one and where) whats No 2 and does it need to be fed into the intake running standard with no Apexi etc yet.
Thanks as always
Thanks as always
