i cant believe you guys!! i just bent the holes by hand using pliers, honestly the metal is really thin, it was a piece of pi55, i even got it to look like it was meant to be like that.
if its the hybrid kit then you use the holes that are already ther but just make them bigger as i described.
the front mount is really easy to fit, the biggest pain was relocating the washer bottle but even that was a doddle.
there is enough room to leave the battery where it is, but you need to unscrew the battery tray and reposition it. same with the expansion tank - just take it off and remount it 90 degrees from where it was, like from 12 oclock to 3 oclock if you get my meaning (im so sh!t at explaining the simplest things!).
hope you have a good angle grinder for the cross member :lol:
