KieranEG6
Well as it stands I became a 1 bar Mong. Wasn't as impressed as I thought I would be. Sooo... onto the quest for more power.
Have done a good bit of reading around on power limits for most parts but as always muchos interwebs conflicting info. Starting to wonder is it really worth going much over 300hp.
As far as I have gathered of parts that become weak/unsafe links
Stock Clutch becomes weak link at around 300hp , but generally ok below unless thrashed.
Stock Injectors are near max above 300hp. Evo 560's are easy option but need ecu.
Stock Turbo can range from 300hp - 330hp , 350hp maxed if your lucky, but even then it's doubtful to last long.
Stock MAF becomes restrictive around 310-320hp. Not really that unsafe but still strong factor.
Gearbox is fine up to around 370hp But factors of Condition and Usage are big factors. Lower limit of 330hp, higher limit of 400hp.
Engine Bottom end becomes on weaker side above around 350hp.
Upgraded Fuel pump and Mappable ECU are general given prerequisites at either points in my opinion.
So In reality it seems for a real step over 300hp (i.e 320-330hp range) you will need at least Injectors, uprated clutch and MAF. (Intake, exhaust, Fuel pump and ECU as well of course).
Then at which point you are pretty much on the limit of stock turbo.
So anything 330-370hp Ideally you need a bigger turbo, next step up on injectors, then you are almost at the point the Bottom end starts reach its limits so forged motor to keep that safe. But then the gearbox is on edge........
Is over 300hp really worth it???
Me being quite a believer in the old saying "While your in there". Seems there is only 2 real options to me keeping on the safe side.
300hp +/-10 on almost stock everything. 1-1.2Bar, Nistune, 560cc's. Mostly all safe.
Unless the clutch goes then its budget depending. Just upgrade the clutch? And enjoy it at 300-320hp.
or forge the motor while in there as well? and look into a quiaf box? Ready for a bigger turbo when the stock one runs out of puff.
370hp+ Uprated clutch, forged bottom end, bigger turbo, stronger box....
Any input, advice or corrections welcome.
