Hi,
Quick question, when altering the base timing at idle after fitting a PowerFC do you still need to go through the same procedure such as disconnect the TPS etc.....
Just wondering if APEXi/AP Engineering would of copied the same logic, doubt it so is it just a setting in the function select menu?
Or doesn't it really matter?
