actuator
beanyv6
what boost does a standard one run at and i've beed told there 6 volts and if u put 12 volts 2 them them run double the boost.
beanyv6
i was told by a garage the other day that they only run on 6 volts and if i put 12 volts through them it doubles the psi
F
Fusion Ed
Um no. Stock the GTIR has a two stage boost, and its controlled by a standard actuator with a 12v solenoid.
