Fazz
hi guys,
so after pig of day fitting 3071 and modifying oil,water actuator, brackets etc its finally on.
trouble is its not boosting.. drives lik 2litre and does rev out.
i suspect the actuator is problem in that it was fitted, on close inspection , wit internal wastegate as open partially in standard form, then to open more if needed via controller.
would i be right in saying the boost won't build up as gate has to be closed to build it, then opened to control it???
if so, then i jus hav to work out how to get fingers in to adjust it!
its a hks adjustable. serious labour went into fitting back yesterday and i see the modifying oil/water pipes everyone has mentioned ! fun! not..
so does internal gate need to be closed to build the boost initially???
