A LITTLE BORING
Roy Archer
As per title.
Im after some experience and advice. Just had some Wilwood Microlite 4 Pots fitted, and i need some help.
1) Suggestions of good pads on the front with the above brakes?
2) Rear standard disks?
3) Rear pads? Standard or uprated?
4) Do i need the engine out to change the brake lines to the master cylinder?
Thanks for anyones help :D
jiw
the master cylinder goes to abs, abs to distribution block, block to calipers 1 line for each front and rear caliper
the dis/block is on the bulkhead, right up behind the engine so i'd say yes, it would probably be best if it was out
creedy
i have wilwoods own make of pad up front on mine. and works a treat on track and road 8)
GTiR_Mic
I just got Wilowood Polymatrix Q pads for my 4 pots, they are about £50-60 from Rally Design.
For the back I have standard discs with Mintex pads.
Mic
