I have a few questions that i could do with answering before putting my engine back in:-
When removing passenger front drive shaft, i removed the six bolts to split the shaft and couldnt split it and whole shaft came out, about 1.5ft long, there is a slot for a circlip on the shaft, but no circlip. Should it have one?
Is there a gasket on the transfer case drain plug, the big flat one?
Anyone know the part number of the belt to remove the air con?
Thanks
Phil
Thanks
Phil
