Right, I have a few problems with the R.
Since getting the Car back from the garage having a new gearbox & clutch fitted it's idle has raised to 1750 :shock: then sometimes the idle wil bounce around like i was tapping the throttle, so it will drop to 1200, then bounce to 1700 odd again... keeps doing it. Only once in a week has it dropped to 1000rpm, but after puling off and stopping again it shot straight back up to 1000.
Fair enough i know the R has a little idle problem like it would start up, go to 1300ish then die down to 900-1000rpm but this is a little different.
Also I get a clunk from the front end when i turn the wheel at low speed. For example turning left at a junction, so stop at end of road pull off slowly, turn wheel left then loud CLUNK, that's the end of it, happens almost every time.
Can anyone help with either? Cheers...
