T
Toady
can the standard block and liners be bored out to fit 87mm pistons or do new liners have to be fitted?
oh i think that the poor lickle engine can stand 87mm pistons without to much trouble :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:Toady said:can the standard block and liners be bored out to fit 87mm pistons or do new liners have to be fitted?
considering the amount of time that you've been a member of the forum and the amount of threads that your post count says you've been involved in,i find it very hard to believe that you don't know the std block will take 87mm pistons.Toady said:have you had it done then? i always thought it could be done untill i took my block round to the machine shop guy last night! he wasnt sure~ :? but im sure he'll find out whether it can or not soon enough!
yes its safe 2 do as i hav had it don on couple of my modded gtirs 8)oap-r said:considering the amount of time that you've been a member of the forum and the amount of threads that your post count says you've been involved in,i find it very hard to believe that you don't know the std block will take 87mm pistons.Toady said:have you had it done then? i always thought it could be done untill i took my block round to the machine shop guy last night! he wasnt sure~ :? but im sure he'll find out whether it can or not soon enough!
when most peeps go for higher boost pressures,87mm forged pistons are usually the std size of pistons that peeps put in.
and in answer to your question-yes i do have 87mm pistons
then maybe you should have done a search rather than sound thick :evil:Toady said:good good! and yeah mr oap-r, i have been a member for a few yrs, and was under the impression that the std block can be bored out that much, but when the engineer queried it...it got me thinking that maybe the people that HAD done this, HAD had new liners put in too. It doesnt make me thick as poopoo for asking, and it doesnt mean i know everything cos i have a high amount of posts! :roll:
just because you've a degree does not prove f_o_ok all,peeps can buy degrees on the internet and if you do have a degree in engineering,then maybe you should have known alreadyToady said:i did do a search! which wasnt much help...ok! :roll: also at what point did the question make me sound thick may i ask? i wouldnt say someone with a degree in engineering is 'fick' would you?
thankyou!paulrandy said:It's impossible to see the thickness of R liners anyway due to the way the block is cast around the liners so not the machinests fault at all.
