4mm spacers for evo brakes!
Gaz gtiR
im geting some evo 3 calipers & 172 discs next weekend! i know i need 4mm spacers behind the discs, now are 4mm wheel spacers ok? i only ask as i had a thought they might make contact with the rear brake pad??
or do i need some sort of spacer that fits inside the bell of the disc??
Gaz
vss irvine
4mm between the hub face and the disc inner face is all you need.
i used washers last time. does the same job
