420bhp & 402lb-ft 'R' £9500 o.n.o
andy gtir
420bhp & 402lb-ft 'R' SOLD
Posting on behalf of a mate :)
:) I've been thinking about moving on to something different for a few months now and the time has come to move onto something with 4-doors - need a family car.
This is the spec as I boought the car from Coxie (Stu) about 6-7 months ago....
ENGINE & TRANSMISSION:-
2 litre SR20DET
Re-bored to 87mm
87 mm JE pistons with JE rings
Crank lightened, balanced, knife edged and polished
Conrods balanced and polished
All new Nissan bearings
Lightened & balanced billet OS GIKEN flywheel
HKS 264 camshafts
JUN Adjustable vernier camshaft pulleys
Full head rebuild including triple cut valve seats, new valves,
Fully ported, polished and gas flowed
Standard manifold ported, polished and Ceramic coated internal & external satin black
Cometic 1.2mm triple layer metal head gasket
ARP head stud kit
ARP conrod bolt set
GT2871R turbo
3" custom turbo inlet pipe
HKS adjustable actuator
HKS SSQV blow off valve
Custom modified engine breather set up
Samco water hose set
Samco blue vacumn tubing.
HKS EVC 4 boost controller
Mongoose exhaust system with de-cat pipe fitted and heat bandage wrapped
Stainless steel water header tank
Stainless steel power steering fluid tank
Stainless steel oil separator tank
Stainless steel oil catch breather can
Stainless steel intercooler pipe run
Stainless steel distributor cover
Stainless steel spark plug cover
Hiteq blue powder coated rocker cover
Nismo high pressure 1.3 bar radiator cap
Standard brand new dampened nissan crank pulley
Forge motor sport billet aluminium pulley set
OS GIKEN single plate clutch kit
Braided Stainless steel clutch pipe
Quaife gear kit in fully re-built gearbox
Short shift kit
Gear stabilisation bush kit
Nismo solid engine mount kit
Hks oil cap
Braided Stainless steel hose on all fittings
Braided Stainless steel oil feed, water feed and water return turbo hoses
Complete throttle body assembly rebuilt
Full Nissan engine gasket kit.
Walbro 255 lph fuel pump
HKS adjustable fuel pressure regulator with aeroquip fittings
Reverse mounted rad fans
HKS S45i iridium spark plugs
Mocal front mount oil cooler system with braided hose
3 inch front mounted intercooler core
Battery relocation kit
Blitz sus air filter
All fixings used throughout car are either stainless steel or anodised blue aluminium
60 mm Apexi pillar mounted boost gauge
60 mm HKS pillar mounted oil temperature gauge
Custom made carbon fibre slam panel cover
Chassis:-
Complete D2 coilover suspension kit with pillowball mounts
Custom made poly rear sub frame bushes
Whiteline anti lift kit
Whiteline sub frame align & lock kit
Fusion motor sport poly power steering rack bushes
Cusco rear upper strut brace
Cusco front lower strut brace modified to clear exhaust system
GAB front upper strut brace
All other bushes on car replaced with poly up rated versions
All sub frame, suspension and under chassis components freshly powder coated chrome
Up rated fully adjustable bump steer kit with protective rubber gaiters
GTi-R spares rear differential guard
Poly exhaust mounts throughout
Brakes:-
Wilwood 4 pot callipers with 310mm disc and rotor with EBC green stuff pads
Standard rear discs with Pagid pads
Fully re-furbished rear brake callipers
Stainless steel braided brake hoses front and rear
Brand new copper brake lines under car
AP racing silicone brake fluid DOT 5.1
Wheels:-
7 ½ “x 16 “Speedline comp 2 alloy wheels in white.
Goodyear eagle f1 tyres 205 x 45 x 16
Bodywork:-
Complete bare shell respray in metallic Poseidon blue including boot floor
Complete under side of shell stripped to bare metal and painted in blue
Complete under side of shell fully waxoyled after painting.
Pro alloy custom chrome windscreen washer bottle mounted in boot
Custom made aluminium battery box mounted in boot
All trim colour coded except rear number plate surround
Clear side repeaters all round
Front bumper modified to accept front mount cooler core
Aluminium blanking plates either side of I/C core
Laguna splitter
New standard Nissan badges on tailgate
Sr20 inside logo on tailgate
GTi-ROC.com club sticker in rear window :wink:
Interior:-
Fully re-trimmed interior including door cards in black/blue leather
All seats re-trimmed in black leather
Standard interior carpet re-dyed black
Alcantara covered dash board with custom pod housing evc boost controller unit
A-pillar moulded pod with 2 x 60mm gauges oil temp and boost
Lockwood white dial kit
Snap off steering wheel boss
Sparco flash2 steering wheel
B and M shortshift gear assembly
Pillar mounted shift light
The car was mag featured in 2006, just after Stu had finished building it and again the car was featured in Banzai in July this year, where it was voted car of the month I have a disc with 110+ pics of the car showing it's full rebuild and receipts from Stu for around 22k+
Since owning the car I have had the following fitted........
1. 3071r turbo, receipt for £865
2. Full Janspeed system inc elbow and downpipe with 5" slash, receipt for £645
3. MSD ignition system inc control box and coil, receipt for £160
4. Sard 700cc injectors, recepit for £180
5. AEM air/fuel ratio gauge, receipt for £180
6. Knock link mounted in dash, receipt for £100
7. New Koyo rad off anothe member, £280
plus numerious other bits and bobs such as........ new hks filter element, new momo wheel, gear knob, razo pedals, head lamp protectors, wheels powder coated, etc, etc the list goes on.... I reckon i've spent 3+ on the car in the last 6 months alone without labour costs.
The car is running 100% spot on and has just been mapped to 420bhp & 402lb-ft with 327bhp @ wheels and a recent compression test showed 160--162--162--163.
I'm in know real hurry to sell the car and it will be cleaned in the next few days and then left in my garage and not used until it's sold.
Here's a few quick pics of how the car looks now, but will take a few more by the end of the week (inside and out) onced it's been fully washed and polished :)
The only thing that needs sorting on the car is the back bumper as it has suffered from a bit of heat from been mapped (which I will sort once sold )
Please don't post saying don't sell, etc, etc as my mind is made up as I need a car with 4-doors for the family and will be REAL sorry to see the car go
One of the best R's around today
paz
If not THE best all round R about today, I absolutely LOVE this car. Good luck with the sale!
Paz
yep would have to say that whoever buys this car, will not get a better one for there money! coxie put a lot of work into that car with no expense spared.
good luck with sale mate, not cheap but still worth every penny your asking if your looking for a real minter.
MATTYGREEN
:) thanks for the comments :)
The cars only for sale as i'd prefer a 4-door (evo or scooby) have an 11 month old son and it would make live ALOT easier. Also fancy a change.
Car is running 100% spot on, if it sells, it sells, if not i'll keep it as every time I drive it it puts a BIG :) on my face :)
I'm locking this thread, Becasue as you know non members can not sell on the forum, That includes mates posting cars up as well :roll: :evil: .
I'll leave it for a day or two then delete it fully.
Unlocked and welcome to our newest full member Matty lol.
looking at and selling are 2 completely different things!nothings sold untill you got the wedge in your hands;-)
a11ova
lovely looking car mate, good luck with the sale:) think you might need it asking 9.5k for it. just my opinion tho.....
