2 things need help for
popcorn
1st is, is there a simple was of de restricting my pulsar, 2nd, tick overs a lil high but cant get to the grub screw with any of my tools ideas on a post card or on here
thanks in advance
Do you mean the 112mph speed limit? Yes, fit a delimiter. You can find them on ebay.
You should be able to get to the screw easy enough, I believe it's the one that normally has a rubber tube over it to guide you to it.
popcorn
nice1 about the 1st 1 ill get hold of 1 of them,
im sure i found the right grub screw just big hands and small spaces dont mix unless there is any pics that any1 has of it unless im lookin in the wrong area but im 95% sure i aint
geetee
You need to disconnect the throttle position sensor and blip the throttle a few times before using the screw to set the base idle.
Have a little Search, it's been covered loads of times. Probably a How To in the How To section too.
