gtir303 said:as above im going 2.2 and im wondering what is the best kit and and where i can get one from at the best price
cheers
carl
speak to rishi stell liners not neededstuart rawlinson said:gtir303 said:as above im going 2.2 and im wondering what is the best kit and and where i can get one from at the best price
cheers
carl
Farndon engineering is where i got mine from they do one offs that will match your needs
Very deep pockets are needed as there really is lots ov things that sld be done as well steel liners, sort out the compression, ete,etc,etc
Stu
JIMMYBACK said:speak to rishi stell liners not neededstuart rawlinson said:gtir303 said:as above im going 2.2 and im wondering what is the best kit and and where i can get one from at the best price
cheers
carl
Stu
gtir303 said:might go for a bore kit now to be different 90mm pistons different linners not sure yet :lol:
warped block springs to mine :shock:RishiGTiR said:gtir303 said:might go for a bore kit now to be different 90mm pistons different linners not sure yet :lol:
You'll defo need thicker liners if you want 90mm pistons....
Rishi
Less torque though.Dooie Pop Pop said:why buy a stroker anyway? :?
peronally id rather build a 2litre engine that revs to 11k+ rpm. you' d get much more out of it than just stroking it.
stu
Cris said:Less torque though.Dooie Pop Pop said:why buy a stroker anyway? :?
stu
Less stress on the valve train too...
actually mine are rather special 8)RishiGTiR said:Unless you know of a piston manufactur who make pistons with thicker walls...
