15x7in wheels with Evo I-III calipers???
velly4
Hi guys,
I'm after a set of 15x7in wheels but having quite a bit of trouble finding something that will fit over the Evo calipers.
I have tried a set of Enkei RPF1's and they foul on the inside of the wheel.
Does anyone have 15x7 wheels with this setup?
vss irvine
you shouldnt have that much bother, i had 15x6 wheels on with the clio 280mm discs and evo calipers. offset was et38.
didnt even need to run spacers
velly4
The Enkei's were +35. Clearence to the inside surface of the is the biggest problem. Spoke clearence hasn't been an issue as yet.
I have no issue with rolling the gaurds if need be so anything from +40 and down.
I'm after wheels that are around 5kg (10-11pounds) per rim.
skiddusmarkus
That's a 15" wheel(volks te37)with 300mm discs but the caliper is very low a very low profile hispec one.There's about 10mm clearance.I also have some oz supert's but there is only a few mm of clearance with those.The volks are very very light but also very rare and very expensive.
velly4
Thanks mate, what is the rough distance from the center of your hub to the highest point on the caliper?
Its approx 160mm with the Evo caliper
