I have at the moment some Gti-R 16inch Enkei split rims from a works R' rally car.Where can i get the bigger R hubs to make them fit a normal R ??? which are 100pcd as you know.
Another option would be to have your origional hubs redrilled to take the new stud pattern., you'd need the brake discs doing too, or new discs if you get the new hubs. Personally, I'd just put wheels on that are for the R and save the hassle.
Looking at the rimstock fitment guide, 114.3x4 with a hub bore of 66.1 is a common Nissan fitment. So you're going to need spigot rings as well, as the standard bore is 59.1. It might be more exspensive than you're hoping for. I think the cheapest option would be to get a good engineering firm to drill your hubs and discs to accept the new pcd.
