0-60
L
levin
read in the newbies FAQ that 0-60 is around 5.5 sec
what performance mods are needed to let a GTIR shave 1 sec off to, say to end up with 4.5 sec 0 to 60 or even faster ?
i realise traction, weight, drivers reaction, ... all have an impact on 0 to 60 times but only want to know what performance mods a GTIR needs to achieve this, saying i need to lose the rear seat and sounds deadening thats true but aint helpful as i dont want to go that route
Just to warn you, be ready for a good roasting now you've posted up this question. ;-)
Autocar iirc, managed a 0-60 time of 5.3 seconds (average of 3) with the best being 5.1 seconds. This was supposed to be on a stock GTiR.
Very little is needed to improve the 0-60 time. Fastguy managed a 3.7 second run with 'just' 246 bhp. Obviously, he did strip the car out a little though.
I'd have thought a car running 300 bhp 280 lb's/ft of torque would be able to get into the low 4's if you didn't care about your gearbox or clutch.
As for mods, a decent turbo back exhaust, free flowing air filter, uprated fuel pump and boost at 1 bar would get those sort of power figures.
EVOBAD
run 300bhp u should hit low 4ss if u can get the gear changes right but i think a strd pulsar is more near 5seconds
LOU ROB said:
You or was it skiddus ;-)
No that was all me :lol: , Surprisingly enough I got the faster 60ft time, Mine was 1.6 seconds and Simon only got 1.7 :? :lol: :lol: :lol: .
gunmetalgtir said:
Really? :shock: That's surprising considering you weigh 30 stone! :lol:
Get your facts right sunshine :doh: , I'm only a slim line 26 stone :shock: :thumbsup: .
Perhaps it was better weight distribution and traction from the increase in weight that helped ;-)
jpward said:
With a Quaife?
They are closer ratio arnt they? :?
Yes mate, The first four gears are a little closer together and 5th is the standard ratio.
jpward
That's another reason to get one now :lol:
Do you think Quaife could make you a longer 5th as i have always found motorway driving revs to be too high?
I'm sure you could for a price :shock: :doh: , I know what you mean though I'm always looking for 6th :lol: :lol: :lol: .
L
levin
can a Quaife box handle that kind of abuse or are these simply close ratio boxes ?
also what type of clutch will hold this abuse ? double plate, triple plate, paddle or some other type of clutch ?
Fast Guy said:
My 3.7 was on about 270bhp ish
erm that is imo just sooooo impressive what did you do to make that happen ?
My quaife has been in for 6 years now and never missed a beat, Killed the first Nismo clutch after 36k of very hard driving and dragging, I had the box rebuilt with new bearing at the same time as changing the clutch, And it held 400 bhp for the last 2 years of proper use, And hopefully will hold the 500 ish I'm planning to unleash on it soon :twisted: ;-) .
Now have a twin plate clutch fitted.
But I wont be dropping the clutch anymore in case I break the casing :oops: .
Mark Turbo has also done 3.9 to 60 on 1bar.
IMO all Gtirs should be capable of that, they just need to be launched hard and driven down the strip like you stole it.;-)
L
levin
what mods did you have then ? i assume stronger clutch and gearbox to take the abuse, and only few mods to get 270bhp like turbo back exhaust, decat, air filter, boostcontroller @ 1 bar ?
Standard clutch, standard gearbox(no sidestepping), apexi induction, mongoose exhaust,colder plugs, dawes device for 1bar, no boost controller, no fuel controller, just all bunged on and the boost turned up:oops:
I killed the clutch at the end of that year,(did a full season on a slipping standard clutch) so now I have an RPS Clutch fitted. I'd have loved to put a new standard clutch in, just to see how long it would last this time.:lol:
