Right got the boost computer running to 1 bar again after playing around with it.
But again after 0.8bar to 1.0bar the clutch seems to slip again, is this possible for it to slip at this point, i have a helix clutch and it has done 200 miles.
i take itu cleaned the oil layer off the metal surface of the pressure plate, also with slightly worn flywheels ive seen new clutches slip untill they bed in which is normally only 10 miles then there fine, but 200 miles, who fitted the clutch m8
