Will these TD Pro-Race 1 wheels fit?
Rishi
Still waiting on some shims!
creedy said:
RishiGTiR said:
You need 100PCD...
35 - 42 offset...
Rishi
the PCD is 114.3 with a 45 offset
creedy
No...
Trust me... I'm right... :wink:
Go outside and measure your PCD and you'll see for yourself...
Rishi
D
deslynam
GINDA said:
Quote from ebay ad: ET35 7J X 17" 100 / 114 PCD
They will fit even the centre bore size is correct.
I may hold you to that! :p
So am I right in thinking that there are basically two sets of mounting holes on there? i.e. the extra holes aren't just for show?
Rishi
So am I right in thinking that there are basically two sets of holes on there that can be used to mount them - i.e. the extra holes aren't just for show?
Well the 5-STUD patern will be the 114PCD and the 4-STUD patern will be 100PCD so they will fit... The offset being 35 so should be fine...
Just need to check the bore as Paul said...
Rishi
GINGA
Q: hi can you confirm that it is 4x114 pcd can you also tell me the centre bore size cheers paul
23-Nov-05
A: hi 114x4 pcd 59mm bore have spigot rings with them cheers phil
:wink: At least I think 59mm is the correct centre bore size iirc :?:
creedy
i have a little book here telling me every car PCD and its says the GTiR sunny is a 114.3
so im just stating what that says.
Rishi
Do a search on the Forum and you'll find that its 100PCD...
Even the fitment guides online say 100PCD...
And my wheels are 100PCD... :D
Which book is this that tells you lies...?
Rishi
D
deslynam
:lol: Where's the internal forum fight going to be then? :)
Looks like i may give them a go, 'acceptable' money for them, not great though as they'll need new tyres.
Thanks for the info, i'll check bore size in the morning.
D
deslynam
eek
0.1mm off, that could be so tight that it'll be infuriating.
Mind you, as you can get new ones for £600 from some eBay shops, maybe £275 isn't such a great bargain afterall once i've put decent tyres on. :(
