What ( roughly ) air/fuel for most power ?
AJ4
As title suggests, am setting up my PFC soon with a wideband O2 sensor, need a target AF ratio to aim for.
Anyone know what is a good starting point for the SR20DET ? 12.5:1 ? 13:1 ?
Just need a rough starting figure, will all be fine tuned in the end.
Ross.
Sirnixalot
13:1 is way too lean for a boosted motor.
stick with 12-12.5 at the most.
I saw something about 5%co being best for power, but I don't know what afr that equates too. :?
GINGA
12.5 is best for power but you risk melting pistons etc at that better to aim for around the 11-11.5 mark to give yourself alittle bit of safety :wink:
GINGA
Also buy the best wideband you can afford and don't leave it fitted just use it for tuning only as the sensors aren't supposed to last that long :(
I have the greddy unit that although it goes from afr 8-16 I don't think its a true wideband and its fairly old and I don't trust it at all relying more on the egt gauge to let me know its lean than the afr gauge :roll:
GINGA
Goes for the hatrick :lol:
Ross with the fc datalogic can it do you a line graph of say rpm against knock so you could do a run then look at what the det levels were throughout the rpm range used so you could fine tune the timing etc :?:
3
323GT-R
Nad said:
Most Widebands last about 300miles.
Nad
:shock: Mine must be screwed by now then... :lol:
It depends what fuel you're using and what EGT temps you get, don't forget some Honda's have widebands fitted as standard, so they can't be all that bad :wink:
ashills
ive got the latest bosch one which is longest lasting u can get
the older style ones are something like 200 hours i think
mines plugged in all time and seems fine and there cheaper than a gtir lambda lol
